Outrun Talon
- 78
- 0
- Aug 1, 2011
Floyd,
Virginia
Two questions here so bear with me
1) I took the little recirculation hose off the stock BOV. You know, the really short curve hose that recirculates air from the stock BOV back into the air intake system about a foot before the turbo? When I did that, my poor Talon ran like crap. in 2nd and 3rd gear at about 3500 RPMs the stock BOV would just constantly dump air out (constant PSHHHHH sound) and the car itself would jerk back and forth (REALLY bad) as you drove it. Is this because it was gaining boost, then loosing it, then gaining it, then loosing it over and over without that recirculation hose? When I put the hose back on, everything worked brilliantly again. Took it off again, and the problem returned.
A) Why does the Talon apparently have to have the recirculation hose hooked up to run (well, run good). I was under the impression that all that hose did was recycle blow off air back into the intake, instead of just discharging it into the atmosphere.
B) If I have to have that hose, how the hell am I supposed to install the HKS BOV that I bought? The whole point of the HKS BOV was to dump air into the atmosphere and get a nice PSHHHH, not recirculate the air back into the air intake. I didn't pay several hundred bucks to get a HKS BOV that was going to do the exact same thing as the stock one!
C) When I took the recirc hose off, I did plug up the hole in the air intake were the recirc hose would usually fit. This way, it was't sucking un-metered air into the intake and turbo. Shouldn't I be able to just plug that hole up, take the recirc hose off, and get the stock BOV to give me a nice PSHHH? And later on install this HKS BOV without having to recirculate air back into the intake after I blow it off?
2) Anyone know were to get a 95 Eagle Talon BOV flange for my Universal HKS SSQV3, or should I just buy something like THIS (link)
Thank you in advance for the help guys, I sure need it!
I see this topic atleast once a week id say.
Not trying to be an ass OP but please do a simple search. If you vent your BOV with out the proper mods you will end up doing damage to you turbo and possibly engine over time. Invest in a maft and GM maf if you want to do this. Do a search for them on here they can be picked up fairly cheap. You can run the 1g maft or 2g the 1g requires some modification with the wires if you search online you will find how to do this as well.
