Block Pic request
ctcare89
99
Nov 12, 2006
Birdsboro, Pennsylvania
I wasn't sure if I should post here or in photography so please move it if it's wrong.
Can I get a picture of the front of an assembled 4g63 block, the right hand side (preferably from different angles)? I just want to double check as I'm putting mine together and I can't find any detailed ones in the photo section.
Thanks
See if these help. If you need more, let me know.
That's almost exactly what I need, except I consider that the side of the block (my naming could be off). Can I get the side that is to the left of that, the side with the exhaust manifold on?
But the ones you posted help a ton, thanks!
If you're bored, you can do the back too haha. The Haynes manual only helps to an extent, I'm really a visual learner.
Thanks again!
Is there a specific question you're trying to get answered?
I don't have any good pictures of the exhaust manifold side of the block with everything installed. I'll post up one that I have though. And here's one of the intake manifold side.
Just to make things easier, the engine is referred to as front (exhaust), back (intake), drivers and passengers side. Right and left are totally arbitrary depending on the location of the viewer.
If you want the front of the block then heres a pic I found in the gallery
<img src="http://www.dsmtuners.com/gallery/files/8/2/8/0/7/newengine001.jpg" alt="new engine" />
