pic request
No pic but mostly run it throw a small hole in the steering column boot! Otherwise you have to reroute it al the way around throw a rubber plug behind your battery!
Or just drill a hole in the firewall!
If you absolutely need a pic a can go and take one!
+1 through the boot. Or drill a hole through the fire wall, but much cleaner through the boot.
I went through the steering boot for mine too.
Edit: I made sure to ziptie everything up and out of the way though, so it wouldn't rub on the steering column or any other moving parts.
