2gb pic request
TurboTsiThatFly
338
Sep 9, 2007
Randleman, North Carolina
I'm looking for pics of the 99 eclipse front bumper cutout for the ssac or vrsf front mount
intercooler. With the bumper on or off of the car. I've been searching but its easier to just
ask people for the request cause there's
Thousands of pics I've looked threw. Thanks in advance. :thumb:
Thanks guys keep the pics coming. :thumb: Also if you guys could measure from the center of the fmic to the edge of the bumper. (just eye ball it to the edge) if you would so kindly. :) :hellyeah:
Why? It's really not that hard. Bolt up the FMIC and mock up the bumper, cut accordingly there really isn't any measuring to be done, just mock and cut, and mock some more. You will be fine. Just cut in little bits. You mount it in your fog light holes everyone should be mounting in the exact same place as per the instructions.....
Punishment kit yes you get to keep you fog lights, but you also get to deal with more potential boost leaks as it is not the shortest route possible. you will have more then 4 couplers unlike the VRSF which only does have 4 couplers.
if your curious about ambient temps i dont see above 8* over ambient, pressure drop is 2 psi according to VRSF and ill be running this bad ass with an HX40 pro
post #19 has your answer. Thanks for reading :hellyeah: :tease:
Okay, you are doing a write up. you basically only need to direct people to ETS to show them how to cut the rad support..... The rest.... As far as cutting the plastic bumper... Like i said, mock and cut. That's probably what you will end up saying on your write up anyway. There area already write ups on how to cut the crash beam if you are going to go that route... The 2gb bumper cover already fits pretty well over it literally all u need to do is mock and cut like 2 inches from the bottom of the bumper and the sides that flare in.
yeah thats all i had to do. I welded the bolts to my rad support supplied with the kit. I makes taking it off and reinstalling alot easier even though i have yet to take it off in the 2 years that i have had it.
