2G Blinker problem
Niteninja01
167
Nov 18, 2009
Milwaukee, Wisconsin
So my blinkers work when the head lights are off, well they blink kinda fast but they both work. As soon as I turn my headlights on both the blinker lights light up and stay on. And when I go to use my blinkers the left will blink more normal, but the right one will blink once and just stay steady on. I'll post a pic to show you what I mean.
how do I fix this? Thanks for the help
Mine had an issue close to yours. Try re-seating the relay for them first. Also, check all the grounds in the blinkers and relay harness.
Uh oh, its the dreaded blinker walk. Time to gut it and make it a drag car, you don't need bllinkers for drag cars. Just kidding I think he meant re SEATING not resetting. But you have the right idea, just pull it and put it back in yes.
My left blinker would stay on after use when it was below 40*then I reseated it and it got warmer ...Also, the passanger side door would latch, but thats a whole different issue.
i usually check all fuses real quick to make sure its not something easier then just do what they said should nothing be wrong, junk like this is usually just ware on wires and fuses, dang factory wires LOL
