blinker faliure
kiddenvy
60
Apr 22, 2005
brighton, Michigan
Whats up fellow DSM'ers. So after fideling with it for so long now i turn to the dsm gods for help.. My blinkers just straight up dont work anymore.. They use to work just fine then cut out one day. When you pull the stalk up or down you can hear the relay kick in but you get nothing, no constent light no hazards no nothing.... I have replaced the relay like three times and have had no luck.. All the bulbs are good, the relays good but i get nothing.. 2 funny related things though.. 1. If i unplug the relay and hard wire the two wires on that lead to the relay togehter(obviously not the groung but the other two) the lights come on but dont flash.. ?? Also with the lose of the blinkers i also lost my power mirrors? So there it is please help i dont know where to turn.. :talon:
Ok, Vehicle profile is filed out my bad... But on to the blinker, i have already gone threw all the fuses.. they are all good...... Any other suggestions?
Well the bulbs all were working when it went out.. and im sure the stalk is good because i can hear the relay kick on but i get no flash.. Is there a seperate flasher from the relay? i know the relay is behind the stereo... What are the relays underneath the left drivers knee protector? Dude im lost... Unless there is a relay or flasher that im missing i dont know where else to look....
I'm having a similar problem too....
I have a 1997 eagle talon esi, 77k miles. About a month ago the turn signals stopped working while I was driving. When I got home I checked the lights.. they were good. At this time the hazards worked. The fuses were good too. The interior green arrows didn't work for the turn signals, but they did for the hazards. I took it to a Chrysler dealer in Iowa, they said the turn signal switch was bad. The part was on back order, so I waited on ordering it. When I was driving back to Kansas my hazards no longer worked. No interior green arrows either. I ordered the turn signal switch and replaced it.... didn't solve the problem. I have looked at the fuses under the hood and by the brake pedal, but the fuses look good. Does anyone know if there are fuses elsewhere or what could be wrong with the turn signals and hazards not working? I've already dropped $200 into the problem and haven't fixed it yet.... and I really don't want to take it back to a dealer when I've always had bad luck with dealership repair on this car.
