Bleeding Brakes, Have a Simple Question!
RallyEclipse98
967
29
Jul 31, 2007
Dallas, Texas
So always in the past when I bleed brakes I just have someone push the brakes and I loosen the bleed nipples in proper order. You know the drill. My brakes have always felt normal.
When I reading on PopMechanics the other day, they said to stick a clear plastic hose on the end of the nipple and then put the end of it in a bucket with some clean brake fluid in the bottom. They say it helps keep air from travelling back into the caliper. This seems completely unnecessary to me as long as the lines aren't full of air. Have you guys ever done this? Will you do this after reading the article? I tried it and it was a hassle and seemed unnecessary.
Link to article: How to Bleed Brakes - Tips on Bleeding Brakes - Popular Mechanics
Thank you for your time!
It has been know to happen on some systems to suck air back into the caliper but very rare does it ever happen.
I do it the way you do. I could see air going back in but if you keep your foot down and close the bleeder before you release your foot then there will be no issues. Now I will say I do put a hose/line on the bleeder to keep the fluid off of my brembo breaks.
