BISS Screw, possibly need a new o-ring?
ChiGGz
280
Aug 29, 2005
Toronto,
One day my car just out of the blue started to idle really bad..i mean like 100 rpm bad and would just start up and die at times. So I checked the BISS and fixed the idle through that. Now I notice a slight idle surge, like 100 RPM difference.
I'm thinking the o-ring on the BISS needs replacing, cause the screw is literally feather light to screw in. If the o-ring was fine, should there be at least SOME kind of pressure as I adjusted the BISS?
Check for boost leaks. Replace everything that you find. If the o-ring on the BISS is bad then you'll know via a boost leak test.
