1G BISS screw leak and TB shaft?
Alex Bland
666
3
Jul 2, 2008
Seabeck, Washington
alright i just wanna know first with the tb shaft, how hard would that be i looked it up online and they took off the whole tb was woundering if that was really needed. also with the biss screw i dont have any tuning software how can i take out the screw and replace o-ring and put it back in without messing up the idle?
To replace the shaft seals, the whole throttle body portion (not FIAV) needs to be torn down. The throttle plate needs to be removed so the shaft can be removed and the seals replaced. This needs to be done off the car.
You will probably mess with the idle if you do replace it. If your old o-ring is leaking and you install a nice, new one, even at the exact same spot as before, it'll possibly change.
