Bilstein B6 HD's...
bastarddsm
5,776
1,710
Aug 26, 2003
Mendota, Illinois
Anyone beside Pagosa doing these? I want rid of my AGX, and this seems like the next best option. Any ideas of the possibility of putting the front inserts in a dsm shock body? How about the strut mounts? I'd like to avoid buying coil over sleve's and springs. I want to run my current springs.
I'm not a road racer, and my car is not lowered much, so I don't need the camber adjustment. I'm running Eibach Pro Kits, will my spring rates be ok for this style of shock? It's mostly a drag car, with lots of street use. It's doubtful I'll ever road race it, but it might get autocrossed 1 or 2 times in it's life. It's AWD and 3400lbs.
Their are 2 ways to install the Bilstein strut housings. I used strut housings and shocts from a 3000gt.
I made my own strut housings, it was a lot of work.
2nd find some old struts from a 3000gt and install the inserts. I noticed you want to use a stock dia. springs. Their is a write up on the Galant sight using a stock 3000gt strut.
On the rear you must make a bushing for the bottom mounting bolt
Rick
