Bigger turbo, pump, injectors... And no afc.
drk mrk iv
238
Jul 31, 2004
Charlotte, North Carolina
I am in the process of putting on a t28killer, 560's, and a 190lph fuelpump. I have all the other supporting mods as well. Would it be unwise of me to put the 560's in without fuel management? I would only want to run 14-15lbs of boost as the settup sits. Good idea, or no.
Do not install injectors without something to control them with. Your car will be lucky if it idles, Let alone driving it down to the end of the block. You NEED something to control the injectors with, And the car will NEED to be tuned.
I definatly would not install injectors with out something to control them with, And I would not install a big turbo without injectors, Everything goes hand in hand really.
I definitely agree about not running bigger injectors without fuel control. I however did it while I was waiting for my new dsmlink chip since the other one went bad somehow. I had no idle or drivebility problems, until I actually gave it more than like 20% throttle and it just drowned in fuel and barely would go, but anything under that was fine. Just an FYI. I was running 650's btw.
My T25 was shot so I started installing the t28 today. I guess I'll run the T28 on stock boost untill I can get afc and the pump installed.
