big 16g will only give 15psi
zachwilliams02
183
Dec 30, 2012
marietta, New York
Hey guys I'm calling upon the dsm gods again. So I just bought a 97 tsi with a 16g and a bogging problem. It took me three days to figure out that it had 550cc injectors in it causing the bog. Swapped them out and it runs great. I'm buying a safc2 soon and I want to crank up the boost. I have a boost controller but I think there is something wrong with the wastegate. No matter how much I turn it up it will be at 10pai. Intill it is fully closed then it will reach 15. I even unplugged muly boost controller from the wastegate and plugged the other end so there were no boost leaks. It still only made 15psi. Is there something wrong with my turbo? Please excuse crappy spelling in some spots. im on my phone
If you have checked to make sure the wastegate actuator isn't staying stuck open, I would do a boost leak test to 15+psi
I don't have a tester and I haven't made one yet. I took the arm off of the flapper yesterday and both the arm and the flapper can move freely. I have a set of headers and an 02 housing I want to put on so ill pull the old one off andtake a look
