big 16g pulls at 4500 rpms? This correct?
97gsx_zeclipse
220
May 4, 2007
San Diego, California
I just installed a big 16g turbo. I am boosting it at 14 psi. I do not have fuel pump or injectors just yet. I will install them soon. Well took it for a test drive and it pulls at 4500 rpms consitantly. Is that turbo supposed to spool that high? Could it be just a boost leak?
Boost leak and you are running lean very bad for motor, get the supporting mods on there
What's the problem?? What do you mean 'pulls?'
You mean to say that it doesn't hit full boost until 4500? If that is the case, then that is definitely not right.
Anyway I don't understand the problem. I think elaboration is appropriate.
