Best Way to Plug EGT bung
98gsspy
272
Feb 27, 2006
Raleigh, North Carolina
What the title says. I read that bolts and lock washers can back out. Does anyone make a plug for the EGT? Thanks
I used to work at a muffler shop and i would see a lot of cars with missing exhuast manifold bolts or bolts that were hard to remove...so it can go either way. What i would do is plug it with a bolt and put locktite..that should do the trick.
Actually brass plugs are better to use if you plan on reusing the bung someday. Brass is self lubricating and won't sieze up in the hole as easily. You might have 1/8 pipe or 1/4 pipe, it just depends. Take your EGT probe to a autoparts store and they can hook you up.
  • Wanted 6 bolt NT water pipe
    • chrisman287
