best injectors for a big16g
captd108
293
Mar 23, 2004
marlboro, New Jersey
I am planning on swapping my stock t25 for a big16g but wanted to also finish the rest of the supporting fuel mods so i can get the most out of my turbo. I got the Safc and the 255lph fuel pump and am waiting for the fullthrottle speed afpr to come. So pretty much im left at choosing which size injectors do i want (550's or 6x0's). I want to try and get the injectors that would be best to run higher psi at. Also if anyone wants to post what injectors they have and what psi they run on their turbo that would be great to so i cna get an idea of what injectors most use at what psi.
if i were you id go 650's.. then you have room to grow.. your gonna need fuel control either way so id go with the 660's or 650's
550s are generally enough for most people running 16Gs. I'd go 660s though for room to grow. With the tuning options out there today running bigger injectors is easier than ever.
what he said ^
thansk for all the replies so far, so far from what i see it looks like 660's are the safest way to go without maxing out your injectors. However how difficult will this be to tune on only an safc, and afpr?
Owning a GVR4 its easy for me to say, get the 650s or 660s and a keydiver chip to compensate. It will idle completely like stock, and you can use the AFC to tune from there.
