bent 420a valves....????=(
racinmopar
88
Feb 27, 2009
addison, New York
hey guys well from my last few post on my timming belt braking i finally got a chance to work on my car for those of you that dont know whats going on i had my timminf belt break while drivng down the road about 55mph.. well with that said i rolled my cams over and i can feel the lobes on the exhause cam but dont feel no lobes on intake... also did compression check 0 on all 4 cylinders:barf:...good chance i only bent intake valves? what your opinions guys you think my valves are bent?
no didnt pull valve cover.. the only thing i know is the ntake cam rolls over easy you dont feel the lobes at all and when i roll the exhaust cam over it wants to rip the wrench out of my hand
Then most likely you only bent the intake valves. Since your compression is zero almost positive that is what happened.
