Bench tuning?
JRSTANGE
200
Apr 11, 2010
Ballwin, Missouri
Yeah bench tuning. LOL! sorry but, basically I've been searching google and other dsm forums for the last few days trying to find an answer to a question that I know is rhetorical question depending on ones setup and tuning capabilities. But, in a sense trying to get a ball park idea of whats capable of my setup given some free injectors I received. I'm sorry as well if this question may have been answered in a past thread but, at least the ones I did find gave mixed information and might not have been specific to given setup.
I have a 90 gsx manual with the following mods: fyi, all maintenance has been taken care of and then some, no boost leaks and pretty decent tuning skills given experience.
650cc
ecmlink v3 lite
afpr set at 43.5psi base
fmic
ssqv recirc bov
2g maf and intake
tdo6h 20g
3" cat free turbo back exhaust
2g tb elbow
etc... further mods can be found in my profile.
I previously ran the same setup on rc 550cc that I had laying around just to get started. I keep intending to purchase say 850cc-1000cc but, just seems I keep stumbling into something else like free 650's.
On the 550's I was running 15psi on about 85% duty cycle and found I was not even making the turbo break a sweat or work really at all based on the compressor map. The car honestly was fun to drive but, no were near as quick as I would like it to be.
I guess what I'm getting at is what can I expect out of the free 650cc's? What type of duty cycles and approx. what boost? given this information be based on knowledge or first hand experience I'd really appreciate it.
I don't have high goals for the car in all honesty anything 300awhp plus would be fine with me. I'm just curious more what it will take to get there. Based on some math and the different fuel flow calculators and the information I can give it; it seems I should be able to make 327ish awhp at 80% duty cycle. But, real world tuning and experience is by no means the same.
I've read mixed reviews of some people running 20-25psi and 18psi and maxing their injections. However no note of what the duty cycle was or any idea of horse power. Sorry for the newbish question but, thank you very much for the help!
does this sounds right?
37.26lbs per min for the 20g at 20psi
650cc @ 100% IDC will support 46.66lbs/min
650cc @ 80% IDC will support 37.32lbs/min
255lph rewired 20psi = 64.34lbs/min
So if this sounds right then perhaps I maybe able to run 20psi assuming no boost leaks which I regularly test for at around 80% duty cycle. The fuel pump should be set to go. Forgot to mention I have a 255 rewired. I'm guessing then if this is correct based on the fuel injectors calculators by hp then 327awhp would be pretty close.
I'll hopefully get to the dyno late march early april.
Again any real world confirmation is appreciated.
Smh, it would have taken less time to resell the 550s & 650s & get 1000s compared to posting this thread & hoping for.... :aha: not really sure what you hope for really.
Really hard for us to tell you a good answer. So many things vary with car to car on tuning. AFR, turbo, maintenance, oil pressure, spark plug gap, timing & tuner.
Regardless, you can make in the 400s with 1000s on a 20g setup with dsmlite. At least that is eventually my plan :sneaky:
Yeah sorry I updated the first post with a 255 rewire. I agree I should have sold tham both and gone bigger. Its also to cold to tune and the car is down in the garage waiting for new injector seals for the fic 650'c and ss brake and clutch lines and so on. As well as its too cold to tune and find out right now.
too many variables, but an average safe tune and those parts on pump fuel, i'd say be happy to get 310-315hp to the wheels at 21-23psi
add alky injection, get a good tuner and bump the psi to 28-30, you might hit 360whp
some may make more, some may make way less.. but for it's flow my safe tuning on pump with a damn near same setup landed 332hp 312tq at 21-22psi the tune was very safe as far as timing and AFR's though, but i knew it would be safe to beat on daily and that's what i'd rather give a customer than a few more HP with the chance of the head gasket popping next week LOL
  • Wanted 6 bolt NT water pipe
    • chrisman287
