BC280 Cam Card Specs
silentscreamer
106
Oct 11, 2008
Moncton, NB, Canada
I purchased a set of used BC 280 cams a while back and they did not come with a cam card indicating when the 0.050" lift degree should be. does anyone have a cam card for these and feel like posting up both the exhaust and intake specs. I tried searching for the specs but nothing was even remotely mentioned. Is this because BC says these are drop in cams and do not require degreeing, even tho they do need degreeing. I am just trying to get some information gather before i send my block away so i am ready to start the assembly when I get it back.
thanks ahead.
I would contact BC for all your needs. However I have these written down that may help you for the BC 280/280. Hope this helps.
ave. duration 280°/280'
duration @ .050" 218°/216°
LIFT (inches) .422"/.418"
LIFT (mm) 10.71/10.60
Timing events
7 ¦ -2
btdc ¦ btdc
31 ¦ 38
abdc ¦ bbdc
