Resolved 1G Battery Terminal Fuses
cficare68
87
Aug 29, 2010
Boise, Idaho
Can anyone show me where I can find a diagram of the fuses on the battery terminal. I have looked for quite sometime and can not find one. The previous owner of the car bridged one of the connects with a piece of wire instead of replacing the fuse so I need to see what the fuse goes to and how many amps the fuse is.
Solution
From the passenger side to the driver side:
Ignition Switch Circuit Fusible Link - 30A
Radiator Fan Motor Circuit Fusible Link - 30A
MFI Circuit Fusible Link - 20A
ABS Circuit Fusible Link (if equipped) - 60A
Solution
I never had the fuse cover but thank you Tanro. 19Eclipse90 thank you. I was actually hoping the last one was for the ABS since I deleted it from the car. Thanks for the responses guys.
