battery relocating kit?
2gdanny
625
17
Mar 9, 2007
south river, New Jersey
hey every i have a question, i have the dsm link and i just got the battery relocating kit is it fine for me to unplug the battery to run the kit , and will i lose my dsm link settings?
What happens when the battery is disconnected from the car?
For the 1G version of DSMLink, nothing. All the changes you made prior to disconnecting the battery will still be remembered.
For the current 2G offering, without the memory board, it works like this. When you order DSMLink, we'll ask which injectors you have. We then burn a chip with default settings for those injectors. So if you loose power to the ECU, DSMLink will still function properly. It won't "forget" anything necessary to run your engine. The things lost will include the adjustments you made to the stock timing and WOT fuel tables. The stock values are still there. You'll simply revert back to those values when the ECU powers back up.
http://www.dsmlink.com/faq.html#battery
You could try something like this and see if it works. It is a memory keeper with a 9v battery and should be available at Pepboys or autozone. I bought one to keep my CD player auto EQ/alignment settings but haven't had a chance to see if it works yet.
  • Wanted 6 bolt NT water pipe
    • chrisman287
