Battery Question?
Ktreece777
50
Jul 9, 2003
IF my car will turn over but not start and the battery is dead but I am giving it like an hour or so to charge could it still be the battery or if it turns over should it be fine
Oh I do, therefore its not the battery.... Could it be my ECU maybe its bad, Is it possible it wouldnt give me a check engine light
If you have spark and fuel than it has to be a mechanical problem with the car preventing air from being there.
I think you should compression test the engine then check spark and fuel again.
Ktreece777 said:
Where might this ECU Fuse you speak of be
on a DSM it would located in the engine bay. like crankbender said i would check the fuel system and ignition system again.
