Base tune with safc2, wideband, keydiver?
jc_is_the_man
40
Jul 17, 2008
New hyde Park, New York
Alright, I'm kind of new to tuning with the safc but I've read up alot on them through RRE and various sites. Anyway, I'm trying to get a base tune going on my car, but the wideband is going crazy no matter what I do (never tuned with one either). I'm trying to get it around 14.7 at idle, and I'll have it right around there but then 15mins later or after a drive it will either lean out or get rich depending on the adjustments I made prior.
Like I said I'm tuning with the safc2 and a wideband. But I also have a chip that is for 650's (I have pte 680 but I've read they flow the same), 2g maf, 93oct, stutterbox, nlts, etc. Main point being injectors and maf. Now I had every intension of having a 2g maf by now, but I don't yet but I still wanted to get a base tune then figure I could zero everything out and start over once I get it. So I was thinking for a start doing -15% across to copensate for the fact I still have the 1g mas in there.
Does it work like that? Because for some reason I'm adding fuel in the lower rpm range and still leaning out when I go for a drive and let off?? I have my wideband welded right after the flexpipe, the exhaust is fairly new but is it possible there is a leak somewhere causing this problem?
*Cliffs*
My main question though was if I could set up a base of ~-15-18 on the safc, if that would work since there is no 2g maf, and it flows that much more air then a 1g.
Thanks John
If your chip is set for the injectors you have, you shouldn't have to fuss with the SAFC hardly at all.
Yes it is set for the injectors I have. But it is also set up for a 2g maf which flows almost 20% more than the 1g maf I have on it now.
Well I had the chip burnt for the 2g maf because I knew it would be a very soon upgrade. However I've been having trouble finding one, and would like to just set up a base tune so I can drive it around for now until I get the 2g maf which will hopefully be asap.
You guys know what I mean? since the ECU thinks it has roughly 20% more air, I should compensate for that by taking out 20% across the board? Or do I have this totally backwards?
