balance shaft help!!!!!
erock1399
46
Apr 27, 2011
ny, New York
hey guys im lookking in to buying a 6 bolt motor. he is telling me it needs balance
shaft in the motor by the crack dose any 1 know where this is and how to fix it
There are two balance shafts. One is run by the balance shaft belt off of the crank sprocket which is located on the radiator side of the block. The other is run by the oil pump and is located on the firewall side of the block.
