hex
- 0
- May 17, 2008
phoenix,
Arizona
Hi, Im pretty new to the DSM world I bought a 98 eclipse GST and have been adding parts slowly. I ran in to a problem that i just cant figure out. The car is acting as if a have a boost leak, at WOT I first over boost then drop 7 to 8psi only to build it back up and drop again. I've made the bosst tester and fix all the boost leaks. I even managed to hunt down the throtle shaft seals. I also took off (completely) the wastegate and added pressure to the bottom nipple. the valve opens but tons of air rushed past the valve in to the exhaust... seems like when the valve opens all the way it startes to close then it kind of opens again. Are wastegates ment to leak boost? is this normal? if it is what else could cause boost spikes then under boost.
mods:
20g turbo
tial wastegate
550 injectors
walbro pump
frontmount
greedy bov
SAFC
AVCR
272 cams
mods:
20g turbo
tial wastegate
550 injectors
walbro pump
frontmount
greedy bov
SAFC
AVCR
272 cams
