bad turbo or boost/vacume leak
Slippi84
4,454
20
Jun 8, 2005
Cinnaminson, New Jersey
I have been reading up on a lot of boost leak and vacume leak forums and no one seems to be having the same problem I am but there are definately signs of a leak or some kind of a/f problem. I have a light cloud of black smoke which makes me think it's my a/f ratio but I didn't even put my 550cc's on or my walbro so why would it be running rich o lean. I ran high boost and after about a couple runs it started to idle like crap. Now I also think it may be my turbo because when I had it hooked up before it would make a descent swoosh or pshhhh however you want to spell out a bov valve when you let off the gass. Now it doesn't make any noise. Is this a leak or is my little ol 14b done do to running to much boost. HELP PLEASE. :confused:
Check your ignition components. If you're getting poor or no ignition on one or more cylinders you may not be able to spool up the turbo. I believe mine to be in this state right now as well, but will know pretty quick here.
- SK
