Bad stem seals? Vid inside
7"exhaust_tip
254
4
Mar 11, 2006
Huntsville, Alabama
Camera couldn't pick up all the smoke, but it was slightly smoking the whole time. Only visible in the video after 2:00 or so.
I've replaced the head gasket, and gotten a new turbo, yet the car still smokes. Supposedly the stem seals were changed when the head was at the machine shop, but now I'm starting to wonder.
YouTube - Bad valve stem seals?
Thanks.
I'd do a compression check all across the board to make sure your rings are in good shape. If they check out, I'd be thinking valve stem seals also.
Compression test is good. I'm probably going to do a leak down test soon.
Where are you feeding oil to the turbo from? If it is an MHI turbo I would feed it from the head.
From oil filter housing.
