brute
- 1,551
- 48
- Jun 29, 2005
Rio Rancho,
New Mexico
When I got my car, the previous owner was running like 17psi. This was bad because there was no AFPR to go with the 290lph pump that was in it. So I took it for a spin, and when boost hits, I hear weird noises and notice my engine bay is smoking a lot. So I pull it over, and see that there's oil all over the engine. I traced the problem back to dipstick-popup. The dipstick would pop up and spray oil.
So I thought the $5 Fram filter catch can might've been causing the problem because it wasn't the stock PCV routing. I returned it to stock configuration and took the boost controller out, running 9psi off the wastegate actuator. This fixed it. I could hit 9 psi and oil wouldn't spray. Just today I put the boost controller back on. I did a quick pull to check the psi I was running: ~15. But no oil spray. I returned home.
A couple hours later, I took it out, tried another pull, and got the symptoms of the top paragraph. Weird noises and oil spray. Could this be a bad PCV? I checked it before and it seemed ok, but then again, my "check" was the dreaded "shake to hear a ball clicking," which in no way tells you if there's a problem with the PCV. I just learned that. Please help.
). It's a one-way valve that should only let air OUT of the VC and into the IM under vaccuum (deceleration, cruising, idle). If it's leaking into the VC, then under boost, you're cramming air through the PCV into the crankcase faster than it can get out the VC breather (see below about the breather). Pull the PCV valve and check it like I already posted.
Keno... Good point, I didn't even think about the psi involved. Thanks!
