Bad PCV?
JCosby
36
Jan 29, 2015
Chandler, Arizona
Hey there, I've got a 1995 GSX. and I was on my way to a car show tonight, and while cruising down the highway at 70MPH and about 3k RPM I noticed the temp gauge get higher than usual, so I found the nearest auto zone thinking I was just low on coolant, but when I would be at a stop light the temp would drop back down to normal.
So I popped the hood when I got to auto zone and went to check oil level and the damn dipstick handle was gone but the metal part was still in the tube. So I picked up a quart of oil and put some in for the drive home just in case. It sounds like PCV issue to me but I've replaced the damn PCV valve on the valve cover twice now.
Idk if I keep getting bad PCV valves or if there is another part of the PCV system that could go bad. and also before the dipstick issue, the metal taps on the oil cap would keep bending up, like pressure build up was pushing it up, the oil cap was from oreillys. So i figured the cap was just crappy I bout a quality one. I hope someone can help me out here :banghead:
Is your radiator sealed to the core support?
Is the rad core clean and free of debris?
common elevated temps at hwy speed is the air flows around the rad and not through it.
"Core"stack can cause it too, FMIC, condenser core, trans cooler core then the rad... the air flow getting to the rad is heated up and restricted.
