Bad gearbox linkage [HELP]
Heryst78
119
11
Feb 9, 2017
Paris, Europe
Hello,
I come to you because after the GST swap on my eclipse, my gearbox linkage seems dead.
Let me explain: Before, on my old engine, I was shifting normally. Now, the first gear goes wrong (sometimes even it is back to neutral itself). The 2nd, 3rd and 4th pass normally.
But I have a hard time passing the 5th. It doesn't hang, but it looks like the linkage is like "Chewing Gum", the linkage seems imprecise.
Has anyone ever had this problem? Does the linkage adjust?
Thank you :)
How sloppy is your shifter? Check the bushings at the transmission end for damage/missing rubber. if your cables have a lot of play before grabbing gear, look into some replacements. I actually just ordered a set from extreme psi to address my sloppy shifter. You're situation however may have more to do with an installation problem since its a swapped setup. Verify your linkage is secured in the proper places. Not missing clips or hold downs or bolts etc.
Thanks a lot :)
I will check all the lines
It was working well before swap so I think you are right, I will check if I didn’t miss a fixation :)
I have check the bushing and they are dead ^^
They missing rubber :)
So I just bought a bushing kit in extrempsi :)
I will have them in a few days, because I’m in France ^^
Thanks again :)
