Bad engine vibration from 3800 to 4500 RPMs
allezgrand
85
Dec 11, 2003
Boulder, Colorado
I am having really bad vibration in the engine between 3800 and 4500 RPMs and it sounds like crap as well. It is a 91 TSi and it does it regardless of whether or not there is a load on the engine. I have new plugs and wires and coil pack. I am 99% sure that there is no problem with the balance shaft alignment either. New capacitors in the ECU and all 60k mile maintenance done. Performance does not change through that curve. The car only has 60k miles on it. I can't figure this out. Need some help.
