bad alternator?
mndsm1
88
Apr 22, 2008
Prospect Heights, Illinois
Started my car earlier today after i changed the power steering fluid and it started right up. now when I go to start my car it tries to start but stops. the lights on the dash are good and so are the headlights. Also before this my car tends to die as I make slow hard turns without hitting the gas.
MMCD handy? -Voltage check :tease: ~13.8 volts at idle, ~12 volts engine off ... loose alt bracket bolt or disconnected grounding strap?
Check your battery. It might have lost charge. If you get it started, take out 1 of the battery terminal, if it stays running, then its good. if it dies its an alternator.
  • Wanted 6 bolt NT water pipe
    • chrisman287
