Backup motor
Fabian972
264
Oct 18, 2005
Garland, Texas
Okay i have a 97 GS-T 7 bolt stock when i bought it has about 160k on th orignal motor i am parnoid i read these threads on crankwalk and i think to myself maybe i should have a Plan B another motor i've seen some jdm 4g63 for sale with tranny what year motor should i pick? I would like a 6 bolt anybody have any suggestions?
any 1g will be fine, there isnt any difference.
however if you buy one just be weary of whos selling it...if your wanting to do an engine build let me know, the business i work for do them everyday and could cut you a deal
There is a difference. The 92.5's started with the seven bolts. I would suggest going with a 6 bolt motor. However you will need to make some changes such as flywheel, crank and cam sesnors, rear main seal, timing tensioner, intake manifold, ect to match the 6 bolt. Any questions let me know.
Fabian972 said:
SO what year where the jdm six bolt used ? :confused:
should be the same. '90 to mid '92 is the 6 bolt, and up is the 7. But owning a 7 bolt motor I would stop reading the crankwalk threads and worry about it "IF" it happens. Next thing you know every time something goes wrong you will think "CRANKWALK" right away.
Mike
