420A Back for some more (420a Turbo)
MitsuRX
Mar 29, 2024
Biloxi, Mississippi
So after getting out of the game for about 8 yrs (sold turbo 420a) I was informed that my old car was found in a field sitting. As i was told, it had blown out the clutch of throw out bearing. So after a lil haggling I decided that i would pick it up and totally redo the car. Time to do good things and redo the car and turbo setup. Ill post some pics later tonight as I'm off to work.
First pics are old set-up ..........
Already have full aluminum radiator and new fans, new IC piping(black) and BO valve. pulling motor and trans and doing the TB,WP and tensioner(Mechanical) and using Gates RPM belt. Trans I already have a stage 2 6puck street clutch waiting just need TO bearing. Ill post pics when i get time to start ripping it apart.
Ok need a lil info from the peeps. Has anybody ever shortened the water pipe that runs from back of water pump. I'm thinking of cutting a section to shorten pipe, as my new radiator( 4bar all aluminum) bottom neck is on drivers side. Any suggestions ?
