Baby Steps......
mike96
1,010
22
May 6, 2008
Phoenix, Arizona
Little by little more and more gets done. i have no pictures for today so i think i will just put up a list of what needs to be done and work on it as i get a chance. i did get the radiator fan installed, with the way everything fit i couldn’t use the factory radiator fan on the install. i ended up using the AC fan on the normal fan side but i still don’t like the way it fits. i may end up looking for something else to replace it. i also got the ghetto exhaust fixed but not installed yet, i want to do something in the gas tank first (don’t want to get the tank open and decide i need to drop the tank to flush it out after i put the exhaust on). Other than that down to the little details.
so here is the list (i am sure it will grow just as fast as i get things done and off)
vacuum lines -- from mani to BOV, boost control, and Mani to intake.
install TPS
wire up MAP
air intake and filter
prime/fill oil
coolant
swap wires for EVO8 ecu
EVO8 fuel pump and rewire
install crappy exhaust
wire in MAFT
hook up battery
finish bolting up front bumper
install clutch slave cylinder and line
bleed brakes and clutch
work rust in trunk
i think that about covers....... i hope
Looks like you've got quite a bit ahead of you, but damn is it gonna feel good after you're done. I have 2 slim fans I'd be willing to sell, lemme know if you're interested thru PMs.
not sure really on the fans part. it wouldn't be a problem if i were to re-do the J pipe. if i re-did that i wouldn't have a problem. there would be plenty of room.... but do i really want to mess with that right now.... i don't know....
