roni-wan
- 155
- 1
- May 4, 2006
merida,
Central America
Hi all just made a first datalog on my 2g 1995 gst at 18psi with the b16g as soon as I hit 18 psi of boost timing drops to 5* and fluctuates between 5-3* thru the entire pull, my afr is high 10s low 11s with aem wideband tuned with maft at -34% think i´m pulling too much fuel but don´t think it will cause the low timing also my coolant temps are 213* during all the pull. spark plugs are brand new BPR7ES gapped at .028 with also a brand new oem coil no CEL´s at all, 93 octane pump gas, no boost leaks. car runs fine and build boost really good pulls hard and the 2nd gets no traction at all with kumho ecstas but third really fells like something is wrong now I know its the low timing.
my mods are
EVO III BIG 16G
STOCK EXHAUST MANIFOLD
2.5" TURBOBACK
31x11.5x3 FMIC
ALUMINUM 2.5" INTERCOOLER PIPING
1:1 ADJUSTABLE FUEL PRESSURE REGULATOR
GREDDY TYPE-RS BLOW OFF VALVE
MAFT GEN-II
GM 3" MAF
POCKETLOGGER
AEM UEGO WIDEBAND
WALBRO 255HP FUEL PUMP REWIRED
SPEC STAGE 3 CLUTCH
FIDANZA 8.5LBS ALUMINUM FLYWHEEL
RC 550CC INJECTORS
HALLMAN MBC
SHORT RAM INTAKE
MAGNECORE 8.5MM SPARK PLUG WIRES
NGK BPR7ES PLUGS .028 gap
COMETIC MLS HEADGASKET
ARP HEADSTUDS
ARP ROD BOLTS
BALACE SHAFTS REMOVED
also replaced the knock sensor about a year ago with a brand new mitsu one, tomorrow gonna check if it is loose and dial the boost to 15 psi and log again to see what happens
any advice its appreciated
my mods are
EVO III BIG 16G
2.5" TURBOBACK
31x11.5x3 FMIC
MAFT GEN-II
GM 3" MAF
POCKETLOGGER
AEM UEGO WIDEBAND
SPEC STAGE 3 CLUTCH
RC 550CC INJECTORS
HALLMAN MBC
SHORT RAM INTAKE
ARP HEADSTUDS
ARP ROD BOLTS
