kenamond
DSM Wiseman
- 3,225
- 68
- Feb 15, 2006
Los Alamos,
New Mexico
My 3" turboback should arrive via FedEx today, and I want to replace the single-tip, round, straight-through muffler with a Magnaflow twin-tip and some 3.5" slant cut rolled-lip tips. I don't plan on going past 350hp anytime soon, so I'm not too concerned about adding some minor bends to get the tips located as perfectly as possible relative to the rear bumper cover (centered, firing straight-back, and closer to the cover (higher) than stock). I'm a perfectionist, so I want to do as much of the mods as possible myself (if you want something done right...), but I won't be able to weld it myself, so I have a few ideas and would like input from those of you with experience and/or knowledge that relates to this.
This is the eBay juicyjems G-Power 3" SS AWD turboback (2.5" from O2 to flex outlet, 3" thereafter). I've been told that the exhaust fires straight back, but I saw atleast one image that looked a bit angled back to the driver's side. Also, it looked like the exhaust came out a bit lower than I'd like. I want to nestle the twin tips as close to the bumper cover as possible, filling that gap that the stock setup has by quite a bit. Also, I'm not yet sure how long the shipped setup's muffler is, so I don't know exactly how much space I'll have front-back with the Magnaflow (HxWxL=5x8x14, 3" centered inlet, dual 2.5" outlet with 4" outlet center spacing). The bottom line is that I'll have to cut and paste, so to speak, to get the tips where I want them.
First question: How close can I get the tips to the bumper cover without a heat issue (discolor/blister paint, melt plastic)? The tips will stick out just as much as the bumper cover (If you look straight down, the tips will be flush with the fattest part of the cover...give or take half an inch or so), and the passenger-side tip will stick out farther than the other, just like stock so that the tips follow the bird's-eye profile of the cover. I'd prefer double-wall tips similar to the stock tips (makes the tip walls look thicker), so maybe that'd help with heat a bit more than a single wall tip.
Second question: Can I use clamps and exhaust couplers to hold the thing together while I'm cutting and pasting and maybe use wire to hold the thing up in lieu of welded hangers? I sure as hell don't want to lose $300 worth of muffler/exhaust/tips on the road driving 45 minutes to a muffler shop, but I'd like to be able to deliver it and say, "weld it so that it looks just like that".
Third question: Can I do all of the cutting with a hack saw, Dremel, die grinder and tin snips/shears? I don't have a band saw or other, more suitable metal cutting tools. If there is a cheap-ish tool that I shold buy, let me know; more tools is always a good thing
Fourth questions
: Would I be able to fabricate the hangers with a vice, hammer (rubber, plastic, metal, and/or sledge) and the above cutting tools? I've never shopped for hanger material; where do I get it? I have a decent set of tools. The toughest hanger might be the one on the back of the muffler; the stock hanger has a bracket welded to the back face of the muffler.
Fifth and final question: I've never done this before. Is this plan loco?
Sorry for the long post. Thanks for the help!
EDIT: I probably should've posted this in a different forum.
Moderators feel free to move it.
Fourth questions
: Would I be able to fabricate the hangers with a vice, hammer (rubber, plastic, metal, and/or sledge) and the above cutting tools? I've never shopped for hanger material; where do I get it? I have a decent set of tools. The toughest hanger might be the one on the back of the muffler; the stock hanger has a bracket welded to the back face of the muffler.Fifth and final question: I've never done this before. Is this plan loco?
When I pulled the first piece out of the box (DP section), I was like OMFG this thing is HUGE. I was wondering for a second if it was some 4" exhaust by mistake. Looks much larger in person.
right now. Last power adder I purchased was my Joe P MBC like 20 months ago.
Just teaches us why NAPA sells that stuff called Anti-Seize.
[Inside joke.]
So I picked up a tube. I didn't want to make your menstrual cramping
any worse, so I used it on the dp/b-pipe and b-pipe/axleback gaskets.
and are still broken.
I may buy the Magnaflow tonight. Or I'll install the silencer and see how much that helps. It's just so loud, especially at 2800rpm. I'm a sleeper fan, and this is wake-the-dead-loud compared to stock. I drove into the parking garage at work, and it was rediculous - echoing all over the place.
