stockh
- 0
- Nov 4, 2012
Charlotte,
North Carolina
If I have a 2g spyder can the AWD drive tran work out of a 1g awd or do I need to find a 2g car
You wouldn't need a different ecu or wiring harness, that is just if you were going turbo and you wouldn't need the harness, just the ecu. There is no wiring in the awd system.You need to find a 2g car. The 1g uses a different transmission, driveshaft, fuel tank, subframe, diff, axles, and suspension setup (possibly other little things too but those are the major ones) from a 2g.
Also I noticed you have a GS spyder. I'm fairly certain that to swap that to AWD you'll also need to swap ecu's and engine wiring harness. Hopefully someone with more experience in this can confirm or refute that for me.
Not exactly. While you could technically use the transmission, transfer case and rear differential, those are only a few pieces of the puzzle. The rear subframe is very different. You'll have a substantial amount of work getting the transmission to bolt in properly. You'll still need to find a fuel tank and just about everything else. Basically, don't bother.
