AWD rocks! 12.7@109
blcknspo0ln
DSM Wiseman
7,772
101
Jul 31, 2003
Central, New Jersey
As some of you know, my old FWD talon only went fastest of 13.9 and quickest of 110mph. These were ran on toyo proxe f4 street tires @ 12 psi. So tired of no traction and crappy launches, I finally switched to AWD a couple of months ago. Almost the same amount power mods, I ran a 12.7@109 at Island Dragway.
Major mods: PTE BB 50 trim (5031RLE) @ 21 psi, SAFC1, Denso 660's, supporting mods, stock long block; running sub 10.5:1 afr and shitty timing advance on a very rushed tuned (as you can see :cool: ).
<embed width="430" height="355" type="application/x-shockwave-flash" wmode="transparent" src="http://s16.photobucket.com/player.swf?file=http://vid16.photobucket.com/albums/b39/thelmasofast/MVI_0457.flv"></embed>
As you can see, I am very pleased with this run seeing how my tune was so crappy and I was only running an SAFC1. This run was done only for comparison to my new DSMLink setup which will be run hopefully in another week and a half.
enjoy :thumb:
great run man. i have always been a fan of your black car and im an even greater fan with the new white on black. whats the deal with your awesome 1/8th but 12.7 in the 1/4? i thought our cars ran faster then that in the 1/4 with awesome 1/8th's like that??? good run none the less man...
Thanks man! I really appreciate the compliment :thumb: The difference on that 12.7 has got to be the severe knocking (or so I think, I can't tell with just a Wideband/EGT because I didn't have my logger nor DSMLink hooked up that run) going on that killed my top end. No fear though, DSMLink tuning is coming along quite nicely. I know the HP/TQ calculator is slightly inaccurate, but I hit 376/350 on 23 psi on 93 octane with NO KNOCK! :D
Usual conversion for 1/8 to 1/4 is 1.55, so with a 8.17 you are just about right on for the 1/4 (12.66 vs 12.7). This of course does not exactly apply to a turbo motor that comes on really strong in high gear. I am used to racing a NA 406ci small block, I haven't ran the Talon yet.
Good Run :)
aaah, another FWD converted over :thumb: I have an ACT 2600 in the car and she holds just fine (smelled funny those two runs, however, because I slipped it for a little too long).
