AWD No movement trans problem
Mitsu0278
Feb 8, 2004
Berlin, Pennsylvania
Mitsu mechanic in need of a opinion. 93 awd eagle talon no movement from trans. The trans fluid is ok and I pulled the pan all clean. All wheels spin freely. I recently bought the car and rebuilt the engine, valve through the piston. I never pulled trans plugs or axles. Cables good and all fuses and hoses attached. All suggestions greatly appreciated. Thanks!
So the wheels move freely but when the car is in gear it wont move at all? if thats the case you can rule out the xfer case that would keep them locked up. That is weird, how it will move freely out of gear but not in gear.
