AWD LSD swap
johnovision27
401
Apr 3, 2008
Ayr, ON, Canada
I haven't come across an answer for this just yet. I currently have a m/t 97gsx non LSD rear diff and have come across a BFH rear diff from an a/t 95 GSX.
Aside from obtaining a passenger rear axle for the BFH diff, are these 2 items interchangeable? If no, what all needs to be done and is it possible?
Cheers
Also, someone should really write up a tech article on which rear diffs can be swapped. Would save a lot of confusion.
The rearend housing is the same for all AWD 2Gs.
The ring and pinion ratio is different for M/T and A/T.
The differentials are interchangeable, but you must match the axles to the diff. (IE: LSD axles to LSD diff, etc). There is only LSD and a non-LSD rear diffs - they are not tranny specific.
So you can use everything but the ring and pinion from that a/t rearend.
  • Wanted 1g 1989-1990 power steering pump
    Looking for 3 piece power steering pump
    • tudds2k
  • For sale 2g 1999 Silver Faced Gauge Cluster
    1999 Silver Faced Gauge Cluster $120 + shipping & paypal fees* the cluster is a turbo/manual...
  • For sale 2g 2G Third Brake Light
    2G Third Brake Light $75 + shipping & paypal fees* 4 oem mounting bolts includedYou must be...
  • For sale 4G63 Aeromotive FPR
    Aeromotive FPR $85 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 2g 2G Gauge Cluster Gauge Pod
    2G Gauge Cluster Gauge Pod $25 + shipping & paypal feesYou must be registered to see...
