qwikmr2
- 0
- Mar 11, 2007
Gwinn,
Michigan
I searched and found a couple of posts regarding similar problems but no real resolutions posted. Here are the symptoms. 90 AWD Talon Tsi
5spd
Car was driving straight at about 30 when all tires locked solid. Upon changing underwear and I found that the engine will idle with clutch in. Release clutch with shifter in neutral and the engine bogs and dies. This car has not had the transfer case recall done. The shifter also does not want to move side to side, i.e. towards 1-2, or 5-R section.
I am new to the whole DSM game but I am quite a Toyota MR2 enthusiast, with plenty of board activity on the mr2oc.com
I believe that the transfer case has failed but I also believe that the transmission is also shot. I could really use some help on this problem and thank you for any help that you can offer.
