2G awd auto no shifting into 3rd or 4th
95twinturboawd
240
Feb 26, 2009
jackson, Michigan
Long story short, put a new filter and fuild and friction modifier, drove and shifted great for a few weeks, then today it wouldn't go into 4th on my way to town then on thr way back it wouldn't go in to 3rd or 4th, so I don't what to check, its a 95 tsi awd stock engine and about 160,000 miles
Are you sure you have enough fluid? You need to shift it through all the gear positions and check the fluid level with the shifter in Neutral.
i put 8qts in i belive, i droped the pan and pulled the line to the cooler to drain the tq converter, and i did said process and in each gear down and up and back to the N.
These cel came on, P0443 purge control valve circuit, P0120 throttle position sensor, P1400 differential pressure sensor circuit.
Could you help me with what I need
Thanks
Jerrid
My 1G auto had a similar issue with 1st and 2nd gear not shifting properly, turned out to be one of the shift solenoids. Could be a clogged valve body also.
