1G autotranny question
mitsufrkr
95
Nov 20, 2002
birmingham, Alabama
ok guys i have a question, what causes the auto tranny in my 90 1.8 laser to be stuck in low gear it never comes out of low gear when in drive . it still uses reverse, neutral, park. just when driving the car uses one gear. buy the way not driving it right now. please help
I believe thats a saftey feature. When the tranny is screwed up it just choses a gear and stays in it. Read your manual....it should say something about it.
the car i a 90 it dose not have a manual. what could i do to fix the problem. i know its not the ecu because my oringnal burned up(leaky caps) replaced it and it still dose it. is there any such thing as tcu that only controlls the transmission. please help :laser:
There is a separate computer for the trans in your car.
Is it stuck in third gear or does it not just not shift out of 1st?
The first step should be for you to see if it has any codes in the TCU.
-John
yes it is stuck in 3rd gear but the car is not throwing a checkengine light or any code. where is the tcu located i will replace it with an nother one and see what happens.
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
