2G Auto Trans Question
mini zilo
783
19
Jul 17, 2006
Chicago, Illinois
Well, I just got a shift kit, and a manual valve, and the pan gasket and filter kit from IPT. I've never done any work on any transmission before, and I was wondering, is it ok to reuse the transmission fluid if you drain it to do work? I realize that if you are down there you might as well change it, but here is what I plan to do:
Install my shift kit and manual valve and my new filter, and change the fluid.
Then a few weeks/one month later I plan to install an end clutch kit and a new transmission cooler. Would I be able to re use the fluid I drain to install these, since the fluid won't be too old it wouldn't make sense to change.
Also, where do you fill the fluid for an AWD 2g trans?
Dude, I'm a cheap ass., but even I wouldn't re-use that shit.
Its not hard to go to autozone, throw in some slighty cheaper fluid, then when you get it all back together for the last time, put the nicer stuff in.
But on the same note, as long as its clean, you can do whatever you want.
To fill generally you just pour into the dipstick. With any auto car.
Actually, why don't you just wait and do everything at the same time? Saves a lot of extra work. And time.
The reason I asked is because I also have no idea how much transmission fluid costs. How many quarts does are car take. I was planning on using OEM fluid. If its cheap I'll just buy new fluid the second time but if it's expensive I don't want to to spend double...
I would think that would be ok as you wont need to drain the fluid to install those parts anyway ,and you wont loose much doing a end clutch or putting on a cooler .And just get a funnel and put it down the dipstick tube .Just dont over fill it.
You have to take off the tranny pan to put that stuff on....
If your unsure on some of this, I'd suggest a repair manual. Or at least a lot of searching.
Cause doing some of that tranny work isn't straight forward. I put a new end clutch on, and looked around/cleaned the stuff under my pan. If you don't know what your doing you could easily mess something up.
The end clutch and cooler, ya, you wont lose much fluid. Had to re-read that part. But still.
I'd just do it all at the same time. Have a friend help or something. The end clutch doesn't take much time at all. The others, well, depends on how well you know that stuff.
Well I was going to use Diamond ATF...what were you using? Does anyone know how much diamond ATF costs per quart?
BTW: the reason I started this thread was because I was under the impression that replacing trans fluid was an 85 dollar thing.... I was getting my source from IPT's site where you can buy 8 quarts of fluid for 85.... I thought that was a little high, but it's probably much nicer stuff...
Diamond ATF and a black bottle of Lube Guard. I've read that on here a few times.
I'm looking to do all this soon too. But I'm going to mass parts so I can do it all at once. Cooler, temp sensor, gasket and filter, valve, shift kit, end clutches. WOO! Should be a pretty sweet tranny after that.
Yeah that's all of the stuff I'm doing in a few days if a weather permits. I just need to know how much people have paid for their Diamond ATF from the dealer. Anyone?
Just would like to add that it takes about 4 quarts to change fluid, i believe I got 2 quarts from flushing it from the return hose and then 2 quartz more out from the pan. And any way you are not changing all of the fluid your changing one third of it, I think the total capacity is 12 quartz just as much as for the cooling system. Someone correct me on this if I'm wrong.
So to really change the fluid you would have to do this process about three times.
Therefore to keep up with the maintance you could change the fluid about every 10-15 thousand miles. I heard a lot of good stuff about Lubeguard and Mobil 1 ATF synthetic fluid.
I not sure about the B&M Trick Shift, someone said that it isn't good for the seals.
