auto to 5speed help needed!
bOOstd GSX
931
Nov 29, 2003
Plum, Pennsylvania
I'm about to swap to a 5speed. What parts do I need, I have a list but if I forgot anything let me know.
shifter cables and shifter assembly
awd 5speed tranny
5speed clutch and brake assembly
master cylinder
slave cylinder (should be on tranny)
5speed ecu
fluids
lines
5speed starter
transfer case
awd 4 bolt rear
Also which of these parts can I get from a 1g. My car is currently getting a 6bolt as well.
PS: if you have any/all of these parts available help me out and sell 'em to me. :thumb:
i swaped mine to a 5 speed you need new mounts we had to custom fab mine because i wasnt waiting :D and also your speedometer will prob not work because it has a wire going directly in to the auto tranny and the manual has no connection port for that but yeah man your close enough if you have anyother question bout this i can prob help. did you get all your parts already ? ps i didnt need a new brake thing
OK, I got a full parts list that I can give you (2g GSX).
You needa couple more things to have what you need. Oh before you get into it, You DONT need a 5 speed ECU.
-Transmission
-Transfercase
-Rear end
-Front drive shafts
-Brake pedal assembly
-Clutch pedal assembly
-Shifter cables
-Shifter assembly
-Flywheel
-Flywheel bolts
-Engine/transmisson separator plate
-Speed sensor
-Upper motor/transmission mount
-Rear transmission bracket
-Starter
-Pressure plate bolts
-Slave cylinder and bolts
-Master cylinder and resevior cup
-Backup light harness
-Clutch line (prefer stainless)
If you need any more help just Email me at [email protected] and I will try to answer them.
Justin
Thanks for the info mrJDMrickard. I'm now going to post into classified section for these parts.
Hey all, i see one of u is from Plum and one from Whiteoak. I live in Penn Hills and have a 2g gsx auto and want to do a swap. Ne1 have any pointers. I have no idea really where to start, but i want it to be perfect and done completely and correctly. thanks
Hey bro whats your name? I used to live in penn hills for like 15 years, I just moved because my parents got divorced. Maybe we can kick it or some shit.
Front Drive Shafts are not actually needed. They are the same between M/T and A/T, you just have to make sure if they are ABS or Not.
yea, boostd, my name is Karac. who r u? do i know u form somewhere? how is ur conversion? did u do it? im tryin to maybe,but id rather get a different gsx if i could find one and find some1 who wanted mine. my aol is viperkd77 too.
