ARP main Stud torque specs with 30wt oil
ShadeTreeDSM
269
Sep 16, 2005
Fort Lauderdale, Florida
i dont have my original sheet that came with my main studs or rod bolts from arp. i already had my block line honed. im finding specs for the main at 60ft lbs but is that with moly lube or 30wt oil, i dont have moly lube so i have to use 30wt oil. while im asking these question anyway, what do i torque the rods and head studs to with 30wt oil ?
The 60ft/lb torque is to be used with the ARP moly lube. 70ft/lb is the torque to be used with 30wt. oil.
Hopefully you can read this...
Previous post is right, I misread the title.
thanks, i waited to torque my crankshaft down, i went and got moly lube today, now im set.
Would you need a line hone after installed? My block has been bored over and I just got a set and wondered if it would need to be taken back for one.
