arp head stud question
Hooah
302
Feb 10, 2003
Olathe, Kansas
Ok heres the deal, i just got a 6 bolt with a blown oil pump....so i figure to stick the 1g head on....the 6 bolt came with arp head studs and i was wondering if i could put them into the 7 bolt with 6 bolt head? ive searched and came up with nothing, i have everything else just need to know this thanks
Tevenor said:
You would have to clearance the head stud passages then it would fit.
That's good advice for getting a 7 bolt head to fit on a 6 bolt block. The way I interpreted the original post was that he was putting a 6 bolt head on a 7 bolt block.
If you were REALLY intent on doing it, maybe you could find a machine shop that would retap the stud holes in the block to 12mm and then use 12mm arp studs for the head. :rolleyes:
  • Wanted 6 bolt NT water pipe
    • chrisman287
