DSMBanditFZ6
- 2,085
- 0
- Nov 17, 2011
Somewhere,
Arkansas
^ That's what I was thinking. Mine would idle around 30. my eg6 runs around 60 on a cold start then drops around 20 at running temp back up to around 50-60 at full boost around 9k rpm that's well over 120mph. (both engines being 2.0l turbo common knowledge says you shouldn't be anywhere close to 100psi at 75-80mph, i'm also going off you being in top gear) too much CCP is a big problem a lot of boosted honda guys have. (granted a lot of people look down on the honda group for clear reasons but there is good info to be had from some of them) It's why I mentioned drilling and venting from the VC with a proper oil catch can. sometimes the PCV just isn't enough with set applications.
And catch cans are very common on these boosted mobiles. A lot of good info in the search bars regarding those David. Probably pick up some lost power from that as well. Too much resistance in your rotating assembly.
Man save some work for me after this weekend. I'd love to work on someone else's car for a change...
kidding. Not bad.
