Chad1993
- 758
- 0
- Sep 1, 2012
Batesville,
Arkansas
I've lost 14 hours of work already!!
. Well I mean at first I just thought it was the dust shield rubbing, but I got the car off the ground to try to fix it but was able to move the wheel left and right up and down quite a bit compared to the others. I can even see the wheel bowed in a little when it sets on the ground. Been snowed in so not able too do anything to it yet.Hey man! Been a while. Well I mean at first I just thought it was the dust shield rubbing, but I got the car off the ground to try to fix it but was able to move the wheel left and right up and down quite a bit compared to the others. I can even see the wheel bowed in a little when it sets on the ground. Been snowed in so not able too do anything to it yet.
EXTREME PSI : Your #1 Source for In Stock Performance Parts
Found this at my favorite dsm shop online.
! The scraping sound was the exhaust hanger rubbing the drive shaft... Getting new plugs and wires tomorrow and a new ECU temp sensor because the car is undrivable when its cold. Has to warm up before going anywhere or it will miss very bad. Been reading some threads and it seems I need a new sensor so im starting with that. Just letting you guys know where i'm at with the car. Runs perfectly fine for the most part though.Changed the sensor now it's drivable on cold starts. No coolant came out? I'm 100% sure my coolant is full.
