aajj1987
- 199
- 0
- Sep 8, 2005
ward,
Arkansas
anyone got a spare radiator?
Sweet!!!
So the ECU worked out, love it.
I have some researching to do...You must be logged in to view this image or video.
>:3 I didn't push it there either.
Smooth as butter.
ok guys got my 6 bolt head back from the shop... im putting it on my 7 bolt bottom end any idea what head gasket I should use? 1g or 2g and I going arp headstuds.... any suggestions on what one lowers compression? shoot me some ideas
WOW kia, that talon look amazing! I have never seen a talon that color before
I am seriously thinking about turning my 2ga gsx into a 2gb talon now. Black talon will look so evil too!
glad everyone seems to be enjoying it.
because its getting annoying having to check oil and adding oil.>:3 I didn't push it there either.
Smooth as butter.
so in order to fix this oil leak I have to replace cam seals and change the timing belt, also what other seals are known to go bad ? Might as well replace them too.so in order to fix this oil leak I have to replace cam seals and change the timing belt, also what other seals are known to go bad ? Might as well replace them too.
Might as well grab an Evergreen full gasket set appox 125 and do all of it, front main, cams, balance shaft seals (or eliminate) front case, water pump seal, etc. you'll be pissed if u have to redo it all for another seal...
